Pros and Cons of Installing PPF on New Cars
A paint protection film is the best example of an aftermarket product that truly works as advertised. Its primary task is indeed – to protect the paint surface and other materials where it’s applied. PPF (which is an abbreviation for this super paint protection film) is a polyurethane-based substance. It’s transparent, and with some elevated brands, it can instantly heal if the top layer is scratched. So, is it a good idea to install PPF on new cars?
In short – absolutely. In fact, this is the best time to apply PPF – or elastomeric polymer film as the primary objective of protective paint films is to maintain the condition of what’s underneath from UV exposure, chemicals, light scratches, toxins, and road grime.
However, PPF is not for everyone. It is a premium product that is typically installed by certified and highly-trained professionals. And there are times when protection film installation is not recommended. So, let’s explore some of the pros and cons of having a clear bra or paint protectin film bonded to your new car’s paint surface.
Does PPF Damage New Car Paint?
This type of material is completely safe to apply to your new car. In fact, most paint protection film customers opt to use this type of protective coating on the clear coat of vehicle’s paint vs a ceramic coating, traditional carnauba wax, or paint sealants due to its safe application. For those who are not aware, PPF is a thin, and uses a unique adhesive substance that bonds solidly to the substrate.
During the installation process, the clear paint protection film undergoes a multiple-stage installation, where it is fitted, cut, placed, and then activated by a liquid spray. The installer will use a squeegee to help apply the film to the painted surface. This is when the adhesive goes to work to attach to the substrate.
There are some vinyl materials or inferior quality protective films with cheap adhesives that will become quite sticky if water penetrates the top coat. In fact, this is more common than you’d think with vinyl wraps. But when it comes to a quality PPF like Ceramic Pro Kavaca Instant Healing Film, you’re 100% safe.
The Advantages of Applying PPF on a New Car
If you’re going to invest in a paint protection film to keep your new vehicle’s paintjob and other parts in mint condition, there are several advantages to consider.
Produces an enhanced finish. While some PPF’s might improve the shine of your vehicle, Ceramic Pro Kavaca is available in a gloss or matte finish. In fact, if you have a high gloss paintjob, you can apply Kavaca Matte – to instantly create a brilliant and customized exterior look and appeal.
Reduced orange peel and lack of glue marks. It’s common for some paint protection films to leave glue marks after the installation. Kavaca’s proprietary adhesive does not leave these marks or creates an orange peel finish.
Superior protection against chemicals and corrosion. Kavaca instant healing protective films are infused with four layers of material, each of them providing roadblocks for harmful contaminants or chemicals to penetrate. It also provides superior stain resistance and reduces paint damage due to stone chips.
Instant healing of minor scratches. Most of the top brands of car paint protection have self-healing properties. This means, that minor scratches can be fixed by a detailer, simply by applying direct heat – or with a blowing heat gun. Kavaca is the ONLY Instant Healing PPF on the market today. It uses nano technology to fill minor scratches within a few seconds.
High temperature resistance. This same nano-tech helps to provide a heat shield, which blocks UV and IR radiation from penetrating to the vehicles surface materials. This unique feature keeps headlights from fogging or fading, which maintains your on-road visibility.
A Limited Lifetime Warranty. Ceramic Pro and our network of more than 3,500 certified installers take pride in providing superior customer service. We prove this by offering a limited lifetime warranty on Kavaca Instant Healing PPF.
Disadvantages of Applying PPF on New Cars
It’s important to clarify that not all paint protection films are equal. Some are simply better and superior to others. As such, there are some things you should consider before taking the plunge with PPF.
Do your research. Before you have a professional place any film or coating on your car, do your due diligence. There are some good protection films for cars – but several ‘less-than-stellar’ ones as well.
Consider your options. There are several professional nano ceramic coatings that will provide superior protection for years. While they’re not as good as PPF for protecting from rock chips and larger road debris, they offer multiple benefits. Don’t be afraid to set up a consultation with a certified installer that offers both PPF and ceramic coating. They’ll guide you to the right product for your vehicle, budget, and needs.
PA
Puteri Amylia
on 31/08/2023
405
